Perform this procedure to view the amount of switch capacity and PoE power being saved on the units.
- Select Energy Saver.
- Select the Energy Savings tab.
Energy Savings Field Descriptions
Use the data in the following table to use the Energy Savings tab.
Name |
Description |
UnitIndex |
Specifies the unit number. |
UnitSavings(1/10 watts) |
Specifies the amount of switch capacity power being saved on the specific unit. |
PoeSavings(1/10 watts) |
Specifies the amount of PoE power being saved on the specific unit. |
